Putting up drywall or insulation?
Old 06-04-18, 07:00 PM
A
In the process of closing on a house in a few days and thinking about a few of the repairs that are going to be needed.
I’m clueless when it comes to home repairs so I’m looking for advice!
While looking at the home we realized that behind the current wood paneling there is no insulation. The previous owners have pieces of normal squares of styrofoam behind the paneling.
Our first thought was to rip the paneling down, put up insulation and then put drywall back up.
Someone else had also suggested just putting up drywall over the wood paneling to save us some money and still better insulate the room.
No idea which direction I should go. Thoughts are appreciated, thanks!Advice and suggestions are appreciated. Thanks!
Old 06-04-18, 07:11 PM
Tolyn Ironhand's Avatar
Received 781 Upvotes on 661 Posts
Drywall has almost zero insulation value. I would 100% remove the paneling and install insulation, then drywall.
Old 06-05-18, 01:27 AM
Marq1's Avatar
Received 1,209 Upvotes on 1,098 Posts
Where are you located, unless you are in a perfect climate where you never condition the living space you need insulated walls otherwise all that money to heat cool just disappears.
Whats the attic situation?
Old 06-05-18, 02:35 AM
Received 785 Upvotes on 688 Posts
What type of construction is this house? conventionally framed with a void big enough for insulation or is it block with just furring strips [only room for styrofoam]? As mentioned above the climate you are located in plays a big part. One big benefit of removing the paneling is it will allow you to add electrical receptacles if needed.
