Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Out of plumb wall for neo angle shower
Old 06-24-18, 04:54 AM
H
Unhappy Out of plumb wall for neo angle shower
all done with tiling and wall is not plumb. Off ~1" at top.
Best advice?
TIA
Old 06-24-18, 06:07 AM
Norm201's Avatar
Received 341 Votes on 307 Posts
So I'm assuming the back of the shower wall does not sit flat against the wall? Can you send pics of the problem?
Old 06-24-18, 06:09 AM
Received 398 Votes on 354 Posts
Is it a problem with the door fitment?
Old 06-24-18, 07:20 AM
H
Further info
where glass side of neo angle shower meets tiled wall, off ~1" at the top. Pan is level, wall is not plumb. Can glass guy cut this 3/8" tempered glass to fit? Anything else to do?
Old 06-24-18, 08:17 AM
czizzi's Avatar
Received 15 Votes on 13 Posts
Once the glass is tempered, it can not be cut. Will have to have a new piece of glass cut and tempered if that will fix your situation.
Old 06-24-18, 08:23 AM
Norm201's Avatar
Short of what Czizzi says you might try and find some type of molding to cover the gap. For instance a jelousy molding that matches the tile might work. Can you upload a pic and maybe we can suggest possible fixes.
I know it might be too late, or lots of work, but is it possible to remove the top few tiles and reposition them with extra thinset or use a shim to bring the tiles into square?
Old 06-24-18, 10:16 AM
H
More
Can I shim out the U channel towards the top then cover that gap? So then the U channel is plumb. I swear that wall was plumb after I was done tiling!
As soon as SO gets back, I will take a picture as I can't manage the glass by myself
Old 06-24-18, 02:37 PM
Norm201's Avatar
I kind of assumed this was a frame less shower. But if you have u-channels then that is the way to go.
Old 06-24-18, 07:01 PM
czizzi's Avatar
Everyone learns the hard way the first time. Part of the learning curve and a great reason to be a member of the forums here. I think new glass is what you need. Trim will not work in a wet location, so lets look to make this a seamless as possible. Removing tile and furring the wall probably is not going to happen either.
Old 06-25-18, 03:22 AM
H
Yes, thinking new glass also. Thanks for the help
