Are these posts/studs safe to remove?
Received 0 Votes
Hello!
I've seen a few similar posts to this but I'm a newby and wanted to get some feedback for my own specific situation.
I want to remove the top part of the wall that separates a big 2-level closet from the rest of the room, to provide easier access to the upper storage area. Having removed a section of drywall, I've found a few studs/posts which I would like to remove. I've indicated them in order of priority: 1 most important to remove, 3 least important. I assume a similar arrangement of studs/posts exists on the right-hand side of the opening. Can you tell me if this is safe to do? I live on the top floor of a triplex in Montreal built around 1900.
Thanks in advance,
Jeremy.
Thanks in advance,
Jeremy.
You would think so... there is no header above it. But you haven't seen or told us what's in the ceiling above, so we can't be 100% sure. If those ceiling joists are parallel to the closet wall then yes, it can definitely all come out.
That doesn't necessarily mean the wall is load bearing. I still don't think it is. The back wall might be but not the front wall.
Not without making a hole in the ceiling. Consulting an engineer on this would really be overkill. A 2x2 wall should NEVER be load bearing, so that would be my final answer.
Received 0 Votes
PLOT TWIST!
After cutting a few holes (not all shown here) and fishing around, and using my stud finder more, I have come to learn that what I thought were joists were in fact just some kind of superficial support beams - possibly "ceiling strapping" - that were perpendicular to the joists and about 2.5" wide X 3/4" tall; the joists themselves were about 11" tall (I could not ascertain their width), and in fact parallel to the closet wall! So I guess the wall can be safely (partially) taken down.
Thanks again for your feedback!
