Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
How To Repair The Wall In Which Stairway Handrail Is Attached
Old 09-10-18, 01:57 AM
Bekrah's Avatar
Iím looking to repair the area in which the handrail is attached to the wall. The fasteners have become detached from the wall and my concern is that if I plaster the wall and filling in the empty holes. The same thing will eventually reoccure.
Any advice would be appreciated.
Old 09-10-18, 02:04 AM
ray2047's Avatar
At the very least the fasteners should have been in studs. Even better is to run a 1x6 the entire length, fasten it to the studs and rail on top. that prevents the brackets from digging into the Sheetrock.
You can make the 1x6 more decorative by finishing the edges with an an ogee bit if you own a router.
Old 09-10-18, 03:47 AM
Bekrah's Avatar
Can you please explain to me what a ogee and a router are?
Should the 1x6 piece of wood be placed BEHIND the Sheetrock? This would take a fair amount of demolition.
Old 09-10-18, 04:09 AM
Norm201's Avatar
Received 729 Upvotes on 644 Posts
I like Ray's idea. No, the 1 x 6 is put on top of the wallboard.Ogee is a decorative molding or use a router make your own on the 1 x 6. You can stain or paint the 1 x 6. Screw the 1 x 6 to the studs the full length of the stairwell. Then attach the rail to it. You still want to attach the rail supports to where the studs are located. I had a similar situation. I relocated my rail brackets and used lag screws that were long enough to go into the studs at least 1 ". Depending on the length, you may want to add two to three more rail brackets.
The only drawback about adding the 1 x 6 is that it reduces the width of the stairwell opening. This might cause a problem if moving large pieces if furniture up and down the stairs.
Old 09-10-18, 04:27 AM
Bekrah's Avatar
Well if thatís the case then, it seems as if I can just skip the 1x6 altogether and just try my best to find the studs while adding a few more handrail supports if need be. Finding the studs seem to be the most important factor here, unless Iím missing something.
Old 09-10-18, 04:34 AM
Received 873 Upvotes on 764 Posts
The handrail brackets should ALWAYS be screwed into the studs! Make sure the screw is long enough to go thru the drywall and into the stud deep enough to be secure.
Old 09-10-18, 04:38 AM
Bekrah's Avatar
Unfortunately, thatís how the place was built.
I purchased the home about 6 years ago and Iíve noticed the handrail fasteners loosen from the sheet rock in which they were attached. Definitely shotty craftsmenship.
Thank you for the advice.
Old 09-10-18, 06:31 AM
W
Received 66 Upvotes on 57 Posts
One of these is handy to help you locate the studs:
https://www.homedepot.com/p/Zircon-S...5945/205143494
Old 09-10-18, 06:53 PM
T
Received 55 Upvotes on 46 Posts
I would sure go with the 1X 6 or a real lumber molding. Not MDF. If you need tio move something through the stairway and it is too narrow, take the rail off remproarily.
Old 09-10-18, 07:50 PM
ray2047's Avatar
Bottom line IMHO the brackets will eventually gouge out the sheet rock and loosen even if the screws are in the studs. Heck, the 1x6 only adds 5/8". The rail takes up much more room.
