Drywall installation in enclosed porch
Hello,
I am renovating an enclosed porch and getting ready to have drywall installed. My concern is that the joists are not completely level and the ceiling will look wavy. Room is 13.6 x 22.6. There will be 6 lights and a ceiling fan centered in room. My normal drywall guy won't check for level, just hang and finish. Ceiling is out no more than 1/2". Carpenter told me it will not make ceiling look wavy if it is left the way it is and drywall hung. Don't want to put out $ to drywall and then have it look weird. Opinions appreciated. Thanks in advance.
It's not really a drywall hangers job to fix uneven framing. I'd either sister on to the existing ceiling joists [that set too high] to make them all level or install strapping across the joists, shimming where needed.
I understand the sistering and or strapping. It is just another cost that would be added on to a never ending project. Carpenter is not dumb, he is under the assumption the drywall installers would shim or realize that something needed to be done if they blew a screw threw the drywall sheet.
Your carpenter is there to see it while we are not but an 1/2" can be noticeable. A lot depends on where the discrepancies are. As you know it's cheaper to fix now than it would be to do it later.
Any carpenter should know that you don't trust a Drywaller to shim a ceiling. That's a carpenters job before the Drywaller gets there. And yeah... I would argue that he's not too bright if he thinks otherwise.
