Loose handrail support
So one of the supports on a staircase handrail has loosened in the wall. The support screws into a 10mm nylon anchor in a wall made of standard clay bricks. The screw is integral to the support so I can't just move to a bigger anchor.
Any suggestions?
Any suggestions?
It's tough when you are trying to anchor to anything that isn't solid. Best thing I could suggest is to use a bracket that only has one center hole, then use a toggle to go inside the hollow clay brick. I assume that's the type of brick you are talking about?
A little nylon anchor just isn't going to cut it.
sleeper, these aren't hollow bricks, they're just normal bricks covered in plaster. All the rest of the anchors are fine and have shown no signs loosening, what happened is I tripped and fell and while the railing kept me from falling down the steps, I managed to loosen the leading support..
Then go with the next larger size of anchor and screw. You could also use epoxy to glue the anchor in place if needed.
I can’t do that because the screw part is integrated into the railing support.
Could I fill the hole with quikrete and then redrill or is that doomed to failure?
No, like I said, fill the hole with epoxy, and butter the sides of the anchor then shove your anchor in. A 2 part paste epoxy like PC7 would work well, provided the hole is clean (Not dusty).
Brace the handrail tight to the wall by using a board against the opposite wall if you can, while the epoxy sets up.
