Joint type for split 2x4
One of my 2x4s is a bit split near the top 2'
i was thinking of just cutting it out and replacing a small section. It's not a load bearing stud just for drywall.
What's the best way to join the 2 together so it's strong?
I thought of a splice type joint but can only do it on one side since the other is a brick wall that it's screwed into.
A lot depends on what you mean by split.
I do not know why you are worried about it since it is not load bearing.
If it is just split and not loose I would leave it or just put a couple screws in to fasten it better to the top rail or a couple screws to hold it together.
A lot of 2x4s have splits in them when you buy them. I doubt it's a big deal especially since it's not a load bearing wall. If I was really concerned I'd sister a 2x4 along side of it.
HeresJohnny, XSleeper voted this post useful.
