40 gallon electric water heater leaking
The water heater is leaking from the top around the where the pressure relief valve screws in to the tank. I replaced the valve since the water tank is 7 years old. The old valve was put in with pipe dope. I cleaned the threads with a brass wire brush and Teflon taped the threads on the new pressure relief valve. The valve is cranked on tight, barely any threads are visible. The leak is not noticeably any different. It is about 1/8 cup a minute, just enough to be annoying. I am beginning to wonder if I have a busted weld where the threads meet the tank.
Received 38 Upvotes
Possibly. It is also possible that you broke the tapping when you cranked down so tightly on the safety valve. You can try a "belt and suspenders" approach by removing the safety valve, cleaning both the internal and external threads and then use no more than two wraps of Teflon tape with some Teflon paste over the tape. It may work, it may not but it is the least expensive thing to try at this point.
"Barely any threads showing " scares me.
It's a tapered thread, over tighten it you will crack the fitting on the tank.
