Water Heater Temperature control gauge does not hold position
Old 07-01-16, 08:14 PM
B
HI Experts,
The model is A.O. Smith FSG 50 232. The problem I have with it is that the control gauge (C (Hottest) B A Hot) seems to go from B to Hot by itself over time after I adjust it to the B setting resulting in there not being enough hot water in the morning.
Which part do I need to replace to fix the issue?
Here is the parts list for ready reference.
http://www.hotwater.com/lit/partslists/PSD1272.pdf
Any help is much appreciated.
Old 07-01-16, 08:37 PM
Received 3,170 Likes on 2,846 Posts
I closed out your other thread about the drain valve.
Not sure what you need here but the pros will be thru.
