Water heater pipe problem
Old 12-10-16, 03:35 PM
Do I remove my old 5 inch pipe on the water heater and I will go to buy a longer 6 or 7 inch pipe or do I extent the pipe?
Old 12-10-16, 03:54 PM
C
Are you replacing the heater or do you just want the end closer to the ground like it is supposed to be? In any case, if you can solder I'd just extend it.
Old 12-10-16, 04:43 PM
ok I'll extend the pipe. Do I use the pipe glue or something else?
Old 12-11-16, 08:08 AM
I'd just use a compression union and a piece of pipe, there is no need to "glue" or solder anything.
Old 12-11-16, 08:15 AM
chandler's Avatar
Or you could use a 3/4" PVC male adapter and a length of PVC glued to it and screwed into the T&P valve.
Old 12-11-16, 09:19 AM
Can I use the brass ferrule to extent the water heater copper pipe .
https://www.thisoldhouse.com/how-to/...hout-soldering
