Water heater temp varies widely
The past few months the temperature of water from my water heater varies quite a bit. Sometimes ts barely warm enough to take a shower other times I have to add cold water to coll it down a bit. Can this be fixed? There is no sediment in the bottom of the tank. Its an LP gas water heater Thanks Tim
Is it only the shower acting up, if so it's not the heater, it's likely the anti scald valve sticking in the control valve.
First thing I'd suspect is the thermostat. Pretty cheap and easy to replace on a gas unit IIRC.
I dunno exactly, but with anything I think has a problem with something controlled by a knob, I turn it upper to lower limit a few times and see if things change.
Doesn't always help, but it sure can't hurt can it?
If you are going to "exercise the dial" then very slowly turn the dial up to near maximum, wait a minute, then very slowly slowly turn it down to minimum, wait a minute, then very slowly turn it back to where it was. Repeat all this once.
Not part of the above test but also try this: If no one has been using hot water for several hours, like overnight, then slowly turn the dial up 1-1/2 notches and then slowly turn it back to where it was. If on numerous occasions the heater kicks on and keeps running for 15 or more minutes then you probably have a sluggish kick on problem that has been known to occur after several years although not with all heaters.
Thanks for the replies.
Yes Allen its typically in the morning for whomever gets the first shower. I usually take that time slot so the Mrs. can have a nice hot shower. I will try exercising the dial and see what happens.
