Hot water heater without Nipple
Old 02-12-18, 05:41 AM
My hot water heater started leaking - possible from the compression fit connecting water line to the hot water heater. After opening up the connection, the nipple was in a corroded state and just came out. I replaced the compression fit. The leak has stopped.
Is it OK to continue without the nipple, or is it recommended to change the hot water heater?
Thanks
Manny
Old 02-12-18, 02:51 PM
Norm201's Avatar
Received 287 Votes on 257 Posts
Did you use dielectric nipples? If not they will corrode last the last ones.
