How does this safety device work?
Old 08-04-18, 11:34 AM
Q
Received 1 Upvote on 1 Post
Hello all,
I have seen this https://www.youtube.com/watch?v=28EJjUDtKiE @03:06.
It has a plastic tube that is claimed to shut down the water heater when the fan doesn't work correctly.
Question> I only see one power line connected to the fan. How does this tube work to turn off the water heater if the fan doesn't work correctly.
Thank you
Old 08-04-18, 03:20 PM
P
Received 1,952 Upvotes on 1,748 Posts
It's a pressure switch which senses the vacuum or pressure generated when the pump is running. If there isn't enough pressure or vacuum to trip the switch then the burner won't turn on.
