New electric water heater: what to look for
Looking at replacing my 10 year old unit.
What variables do I need to look for?
Height? Volume? Existing wiring and circuit breaker?
Current unit is 179 Litres (39 imperial gallons). 46” tall.
I could probably go up to 55” tall. The unit I wanted needs 10 gauge wiring and a 30 amp breaker.
I didn’t realize my existing wiring and breaker would limit so many choices. I read a lot about the physical size of the units but there doesn’t seems to be much education about the wiring constraints when shopping.
How are the Rheem units at Home Depot? I’m looking at model 629872. It has a plastic drain valve. Wonder if you can buy the brass valve from the 667928 model and swap it out.
most likely need to upgrade wiring to 10 gauge. 30 amp breaker as the elements are 4500 watts.
A disconnect is needed if breaker panel is not line of sight.
If you can fit it get the westinghouse lifetime heater. stainless steel tank.
The only caveat is the element replacements need to be stainless. They are pricey..
https://www.homedepot.com/p/Westingh...045N/300903243
Otherwise go to Ferguson and get a bradford white.
https://www.ferguson.com/product/bra...ww/_/R-3363468
What wire size and breaker does your current circuit have? You most likely already have 10 AWG wiring and a 30 amp breaker. A 4500 watt unit must have #10 AWG wiring, but can use either a 25 or 30 amp breaker.
Since your wiring limits you to 3800 watts, you'll have to look long and hard to find a new water heater that meets that requirement. The best thing to do would be to install a new circuit with #10 AWG wire and a 30 amp breaker since most new units are 4500 or 5500 watts. If a new circuit is out of the question or impossible there is another option. You could buy a new 4500 watt water heater and change the elements to 3500 watts. Lowes has them, but it'll cost you about $22 more and you'll sacrifice some recovery speed.
https://www.lowes.com/pd/Utilitech-W...lement/3693202
