Thermal Switch Keeps Tripping on LP Water Heater
Old 09-27-22, 08:33 AM
D
I am repairing a 50-gallon LP gas water heater manufactured by American Water Heater Company (Model BFG6150T403P). It is about nine years old and the pilot light went out and could not be relit. I have replaced the burner assembly and the gas control valve unit with new, cleaned the combustion chamber with a shop vac, and have temporarily removed the dust screen so there is adequate combustible air. The pilot lights on the first try and, after the thermopile heats up (about 30 seconds), remains lit with the correct indicator light flashing. The burner ignites shortly thereafter and appears to be operating normally. However, after about 10-12 minutes there is a “click” and both the burner and pilot shut off. There are no status lights that indicate what the problem might be.
It appears that the thermal switch keeps tripping. I can relight the pilot after resetting the switch, but it trips again after the burner has run for another 10-12 minutes. The thermal switch is new (it came with the new burner assembly) so I do not know if the switch is bad or if there is something causing it to trip. Any thoughts?
Old 09-27-22, 11:11 AM
C
Received 134 Upvotes on 110 Posts
Make sure there are no obstructions in the exhaust venting, like a birds nest or other animal nest, etc. Check the entire exhaust path all the way to outside.
Old 09-27-22, 08:48 PM
Received 3,593 Upvotes on 3,222 Posts
Many times the manufacturers will raise the thermostat limit temperature.
Did you check for a new subbed part for that water heater ?
Old 10-01-22, 10:21 AM
CasualJoe's Avatar
Received 178 Upvotes on 161 Posts
Ok, it's made by American Water Heater Co., what brand water heater is it? Is this a Whirlpool water heater?
