How to replace a 10x54 Kinetico Model 1550TC dechlorinator for sulfur smell
Old 02-12-16, 01:56 PM
R
The Kinetico Model 1550 TC has a 10x54 dechlorinator tank and a 10x54 resin tank along with a standard brine tank. The dechlorinator tank was apparently added to the well water system to remove the sulfur smell - there is not chlorine in the water.
How can I inexpensively replace the dechlorinator tank with one that has fresh carbon in it since the water is beginning to smell a little after the tank has been used now for 7 years?
Thanks for your help!
Old 02-13-16, 04:57 AM
biermech's Avatar
Received 3 Votes on 3 Posts
The tank should have a top that will unscrew. Pour out the old media and replace with new. I would recommend catalyst carbon.
Old 02-14-16, 02:56 PM
R
Thanks for the reply Biermech! Any recommendation for an on-line provider of the catalyst carbon? Also, I remember reading somewhere that a need to perhaps reestablish a bed of gravel, fill up the tank with water and a cup of bleach, let stand for a while, drain and rinse out then pour in the carbon with a good funnel. Probly ought rinse the carbon out with water too I suppose.
Thanks again for your suggestion!
Roger
Old 02-14-16, 03:10 PM
Received 102 Votes on 89 Posts
Any time I've had that issue I just installed a whole house activated charcoal filter and never had an issue after.
Old 02-15-16, 05:19 AM
biermech's Avatar
Disinfecting the tank is not a bad idea. After filling with the carbon, add fill with water and let sit for awhile. PM sent.
