Autotrol 460i Manual Regen Question
Old 07-21-16, 04:32 PM
H
Hi, I am new to the forum, thanks for any help.
I have just bought a house which has a water softener with an Autotrol 460i controller. Our water is not nearly soft enough, so I found the manual and am going to try adjust the system.
In the manual I noticed something that doesn't make sense and I was wondering if anyone knows the answer: in the Manual Regeneration procedure, it says to do the following steps:
Backwash, Brine and slow rinse, Brine refill, Fast rinse/refill
But on the dial, there is no "Brine Refill" position. Is this an outside procedure? A hidden option on the dial? See image below
Old 07-21-16, 05:56 PM
Akpsdvan's Avatar
Received 6 Votes on 6 Posts
You have posted about a softener, but it is possible that you have a filter control and not a softener.
Is there a salt tank?
Old 08-02-16, 08:19 AM
T
It refills at the same time it fast rinses. The salt dial setting determines the capacity per regenerations and the hardness and capacity settings determine how many gallons it will go in between regenerations. Need to know more for proper settings and salting. Size/model number of unit, water hardness, iron etc
