water between reverse osmosis and refrigirator
Old 03-17-17, 01:29 AM
R
Hello,
i have RO installed under my kitchen cabinet
I have installed a water tube between RO and refrigerator in order to get RO water from my fridge water system
this is the tube my plumber installed
https://www.amazon.com/iSpring-Conne...B008H71Q4C#Ask
The tube is running from my Sink cabinet to underneath cabinets and to refrigerator. in between there is microwave oven installed and the tube is running beneath the oven. when i turn on the oven it generates very high heat at the bottom .
since the tube is running underneath the oven ( i dont have any other choice but to run the tube underneath the oven), will it get impacted due to high heat ?
if it gets impacted then how should i insulate it ?
Old 03-17-17, 01:56 AM
Marq1's Avatar
What is the distance between tube and oven.
Microwave generating high heat? I dont recall than my Microwave gets very warm.
Old 03-17-17, 05:55 AM
P
Received 1,628 Likes on 1,461 Posts
A residential oven should not radiate enough heat to hurt anything since they are designed to be placed on and have wood right up next to it. There might be enough heat to eventually make the water in the tube warm but it should not get hot enough to damage even plastic tubing. After all, the oven doesn't radiate enough heat to damage the finish on cabinetry or to damage wood or vinyl flooring.
Old 03-17-17, 09:32 AM
R
Thanks for the replies. sorry its Oven
whenever oven is turned on i can feel heat coming out form the bottom to my feet and its bit hot. in my next reply i will take image and upload it
i agree the heat wont spoil wood or the vynl. i am just concerned whether it impacts the water tube. of something happens to the tube when i am not in the house i will end up have watery house
Old 03-17-17, 09:55 AM
Marq1's Avatar
sor
ry its Oven
So that makes more sense. This is a built in oven, inside a large cabinet?
Tube is running in the cabinet or under in the toe kick area?
Distance from oven to tube?
Old 03-17-17, 10:02 AM
R
yes this is built in oven with cooktop. tube is running under in the kick toe area. i think distance is just minute between oven and tube. i am at work right now. once i go home i will take pic and will upload it here
