Waterboss softner
Waterboss softner
Too much water in the cabinet. Tried to clean the piston and check the washers in the inlet and outlet. Can't get to the bottom screw to remove the housing because of the magnetic disk and the brime tubing came up from the cabinet and I can't get it to go back flush with the cabinet.
Is the brime hose connected to something in the cabinet? How can I remove the screw and put the tubing back in the cabinet
