Brine tank not refilling with water
Old 06-30-17, 05:44 AM
Hi all,
I have a Culligan Iron Soft Plus water filter setup and I've noticed that the brine tank has stopped refilling with water.
Water is still being pumped out during regeneration because the salt and water level continue to go down after adding salt, and manually adding water.
We just purchased the house two months ago and I've never dealt with a water treatment system. Would someone be able to give me some ideas on what to check?
Thanks in advance!
-Jason
Old 07-02-17, 12:38 PM
Akpsdvan's Avatar
Received 7 Upvotes on 7 Posts
Check the float assembly in the salt tank in that it is free to move up and down, it could be that the float assembly is locked in the up and stopping water from coming in.
