Salt is salt?
Salt is salt?
Another thread got me thinking about this question. As far as the functioning of the water softener is concerned does it matter what type of salt I put in the brine tank?
When I moved to my current home 24 years ago there was about 2 inches of sediment in the bottom of the large brine tank that I assumed needed to be cleaned out, about 1/2 of which were small pebbles. I'm assuming the previous owner used rock salt in the tank. I switched to "System Saver" pellets for a few years until a softener service guy recommended I use the more natural Solar salt.
But does it make any difference or should I just use whatever is cheapest--like the previous owner did?
Marq is correct up to a point. Depending on you needs you might not want to use Solar salt.
Look at this site for a more detailed idea of what you will need.
The Best Water Softener Salt To Prevent Mineral Build-Up
