Is a sediment collector needed with a Fleck 5600SXT 48,000 Grain Water Softener
Old 11-15-17, 03:50 PM
R
I just received my Fleck 5600SXT 48,000 Grain Water Softener Digital SXT Metered Whole House System and I also bought a 3 tier sediment collector thinking I would need both. I have hard water and for the most part the water in the sinks and showers is clear with the exception of the large particles that come from the ice machine. I replace that filter all the time but does not help. What I am trying to decide is if I just can get away with the water softener and send back the sediment collector? Or should I just order a Corbin filter and if so where would I install the carbon filter (before or after the water softener). Same question on the 3 tier sediment collector where would I be best to put it. Thanks
Old 11-15-17, 04:44 PM
Marq1's Avatar
Received 462 Votes on 430 Posts
When you say sediment collector are you referring to some type of water filter? I have not heard that term before.
A water softener will not filter the water, same with carbon filter.
My system has chlorine injection, Big Blue water filters, GAC carbon filter, then water softener.
https://www.doityourself.com/forum/a...1&d=1510789486
Old 11-15-17, 05:03 PM
R
10" Whole House 3 stage filtration water system + extra 3pc filters WH-3+3
This is what it is 10" Whole House 3 stage filtration water system + extra 3pc filters WH-3+3. PureWaterClub.com
Old 11-15-17, 05:40 PM
Akpsdvan's Avatar
Received 6 Votes on 6 Posts
Depends on the water quality.
If there is a lot of sand and sediment then maybe if there is none why spend the money?
What did the water test show? Was the test simple or complex?
Old 11-15-17, 05:52 PM
R
Simple water test
they just tested for the normal but I know where I’m located the water is full of sand. I can see it in the tub. Besides that we see the normal white spots and the water is hard per the county website
Old 11-16-17, 03:09 AM
Marq1's Avatar
If you are getting krud in the water then a filter is needed, it will eventually fill up the water softther and other mechanical.
Big blue filter is great, filters are cheap.
https://www.doityourself.com/forum/a...1&d=1510826973
Old 11-16-17, 07:22 AM
R
Big blue.
Okay cool. Think I’m following. Big blue would be prior to water softener with what micron level? Then I could do the 3 tier filter after he softener before it goes into the house??
Old 11-16-17, 10:03 AM
Marq1's Avatar
20 mu will get all the krud out of the water. The polypropylene filter are 2-3 each when you buy a case, I switch them out every 3 months.
They are good to also get out the non soluble iron/rust which will help keep WS clean.
You really wont need a post filter especially if you install one of the large carbon filters.
Old 11-16-17, 03:11 PM
R
Thanks
Thank you for all the help.
