Disconnecting old whole house water filtration system
Old 01-11-18, 02:22 PM
C
We moved into a house with an old water filtration system that we would like to remove. I assume it is connected somewhere underground to the main water line and run around the house to the back yard where the filtration system is located. How big of a job would it be (if I can find the connection) to disconnect the water filtration system so I can remove it? Thank you
Old 01-11-18, 03:48 PM
Received 129 Upvotes on 114 Posts
Highly unlikely any filter is located under ground,
We have about 0 info on what you really have,
Old 01-11-18, 04:41 PM
Marq1's Avatar
Received 1,211 Upvotes on 1,099 Posts
Impossible to say based on your description, some pictures would be helpful to see what you have!
Old 01-12-18, 07:32 AM
C
Sorry... the system of two tanks is located a shed in the backyard. I would like to remove this system but I need to disconnect it from the main water line before I do. The connection is buried in the front yard.
Old 01-13-18, 04:13 PM
Akpsdvan's Avatar
Received 9 Upvotes on 9 Posts
Either some photos of what we have been asked to comment on or just find a contractor to do the work of removing the system from the water line supplying the house.
