460i Water Softener Troubleshooting
Old 05-02-18, 06:44 PM
C
Exclamation 460i Water Softener Troubleshooting
Hello, I need help determining what is wrong with my softener. I came home after work and it was constantly fast flowing in the drain. Panicking I put it on bypass and disconnected
the power without looking at where in the cycle it got stuck. I then proceeded to do a manual regeneration In which it completed. So I know the gears are good. Since its on a metered basis, I reset the clock and hoped for the best. The clock kept its time accurate until I again came home and it was stuck on backwash and the timer was flashing rapidly the number 8. So I put it back on bypass and unplugged it. Giving it a little time hoping it would go back to the default setting, I plugged it back in. I still get the crazy 8. I can no longer set the time or program it. Now, thank you for you patience with this book, do I need a timer motor or should I just bite the bullet and buy a new one.
Any help would be appreciated.
Thank you,
Caroline
Old 05-02-18, 08:21 PM
Akpsdvan's Avatar
Received 7 Upvotes on 7 Posts
Sounds like just replacing the 460I controler will do the job.
There are a few places on line that sell them new and there is a place or two that sell them used.
Timers do go bad from time to time, and the digital ones just get replaced.. mechanical can be repaired at times.
Old 05-03-18, 05:40 PM
C
Thank you for replying. So replacing the timer assembly should do the job?
Old 05-04-18, 09:49 AM
Akpsdvan's Avatar
From my understanding of what your saying, it temp resets til it starts a cycle then Fracks up...
Digital controls often can not be repaired in the field , just replaced.
Yours might new might be around 200 but that is way cheaper than a full new system.
You might also be able to find a good used one for a lower price.
Old 05-04-18, 03:23 PM
C
Q
Thanks you very much. Enjoy your weekend
Caroline
