Softener Pressure Relief Valve Leak
Old 10-22-18, 04:57 PM
P
Hi All,
I own a Kinetico Mach 2060s which has recenlty started to leak water from the pressure relief valve located above the pre-filter housing. The leak is coming from the valve housing that attaches inside the pipe, not through the drain tube itself.
I would like to repair this leak myself but lack knowledge of water fittings.
Is this repair simply replacing/cleaning an o-ring with silicone, or should the entire valve part be replaced?
Also, how is the valve removed from the housing, is a special tool required?
Any help is appreciated
Old 10-22-18, 05:59 PM
Akpsdvan's Avatar
Received 6 Votes on 6 Posts
If it is new enough have them come and fix it........
Old 10-24-18, 09:18 AM
P
unfortunately the warranty has expired
Old 10-24-18, 09:33 AM
Akpsdvan's Avatar
It looks like a John Guest fitting.. they are like the shark bite fittings.
will your local dealer sell you a replacement fitting?
Old 10-25-18, 05:39 AM
P
Thanks Akpsdvan for pointing me in the right direction. I did some reading on John Guest fittings and believe this 90 angle valve part is a quick connect type fitting.
I found this Kinetico illustration of my system which shows the relief valve and what appears to be a O-ring on the stem. So at this point it looks like I don't need a new valve, but only two new replacement O-Rings, 1/4" and or 3/8".
Question: Should silicone grease be applied to new replacement EPDM O-Rings?
Old 10-25-18, 09:16 AM
Akpsdvan's Avatar
Just a LITTLE......... it does not take much, just a light coating.
