Adding Storage Tanks to RO System
Old 02-23-19, 11:21 AM
Received 3 Upvotes on 3 Posts
Greetings,
I have an under-sink RO system that has the typical single 4 gal. storage tank. I would like to add one or possibly 2 storage tanks to the system. Before I do, I wanted to post a couple of questions to the experts here.
First, is there any reason why I should not or can not add multiple tanks to the system?
Next, if I have 3 tanks total, is it better to connect them using Y fittings vs tee fittings?
And lastly, if I have 3 tanks total, and I use Y's vs Tee's, where do the Y's go with 3 tanks?
I appreciate your time and any advice you can offer.
Steve
Chandler, AZ
Old 02-23-19, 12:10 PM
Akpsdvan's Avatar
Received 9 Upvotes on 9 Posts
Tee's will work just fine. Space will be some thing to look at or going to a bigger tank would cut down on tube runs and tees or elbows.
I did one about 18 months ago when two 65 gallon tanks where plumbed together with a tee to bring them together and then feed the line to the dispensing faucet.
One might also look into a better quality ro system that can make more gallons per 24 hour time frame.
Water temp does play a part in gallons per day.
Old 02-23-19, 12:46 PM
Marq1's Avatar
Received 1,211 Upvotes on 1,099 Posts
Holly crap batman, must be some commercial usage??
Old 02-23-19, 07:35 PM
Thanks for the reply.
Fortunately, space isn't a concern, at least not for the size tanks I'm talking about. 65 gal. monsters would be a challenge.
I pulled the trigger and bought 2 tanks today from Amazon. They'll be here Monday. If I run into any issues, I'll be back to pick your brain some more.
Thanks again!
