Any easy way to melt brass ?
I would like to make my own brass belt buckle but don't have the equipment or space for the traditional way of casting. Any short cuts that work?"
I'm no expert but you need to get around 1,700 degrees and I can't imagine any sensible way to do that except using a furnace. My suggestion is to try to find someone in your area that has one (perhaps Craigslist) and pay to use theirs.
Sounds like a crazy project. But if you havent, you might go to youtube and search for "building a foundery". My brother-in-law made one inside a steel bucket that melts aluminum cans which he pours into ingots. What he's going to do with them, I don't know. I think he just likes playing with fire.
Otherwise you'd need to locate a smelter in your area. Using google I found some in your area. You'd have to call to find out what they'd consider a short run of brass. You would probably need to do your own sand casting too.
I think with brass you may need a graphite crucible.
As you've already heard the only way to melt brass for casting can be done many ways. It's not rocket science but it does require building some stuff. The only other option I can think of is to get sheet brass and cut out the buckle you want. Hammering and filing could get you the rest of the shape you might want.
