A/C drain pan surface coating
Hello all,
My Furnace Drain Pan is rust.
I would like to protect the surface with a product similar as PANCRETE. The pan is of size 36"x36".
Question> Can some one give me suggestion on which other products I can use?
I prefer the product is water-based and self-level b/c some area of the furnace is hard to reach.
Thank you
Thank you
Hello PJmax,
Very glad that you read this sub-forum too!
The drain pan is of size 36"x36" and I only need to seal 60% of the area with the coating and the other part is sit with hard-insulation foam.
Since most of the area needed coating is under the furnace and I will not be able to reach with brush. Does this product self-level?
Any difference between this and https://www.amazon.com/dp/B00PHNPG90?psc=1 Rubberseal Liquid Rubber Waterproofing and Protective Coating -- Roll On WHITE?
Thank you
Thank you
Does this product self-level? Yes.
This product is also available at some home improvement stores.
flex seal products/stop-leaks/
