Unbend piece of steel
Old 10-11-17, 03:43 AM
D
I have a very old bike.
The only problem is that the head has been bent by a shock.
I'm wondering what would be the least suicidal approach to try to straighten it back without breaking it.
Should I just try to hit it with a sledge hammer or should I try a slow solution like stick it into some corner and bend it, should I heat it up,...
Thanks
Old 10-11-17, 03:51 AM
V
Received 3 Upvotes on 3 Posts
I think you should be able to find a Welder or a Blacksmith who can heat the handlebar up and bend it to where the two sides are even.
Maybe that Bike dates back to a time when people had arms of different lengths and they had to make bicycles to fit their asymmetric bodies ?
Old 10-11-17, 03:58 AM
Received 835 Upvotes on 732 Posts
I'd apply heat and then bend it. Just beating on it is apt to break/crack the steel.
Old 10-11-17, 05:05 AM
P
Received 2,153 Upvotes on 1,928 Posts
You can also replace the quill stem. There is a large selection less than $15.
Old 10-11-17, 05:12 AM
Received 128 Upvotes on 113 Posts
I'd be removing the bolt to see if it's what's bent, and just replace it if it is.
