Use Battery Charger with Watchdog Backup Pump
Old 04-10-16, 09:39 AM
I have a Watchdog Emergency Backup System, which some of you know does not charge the battery 100%!
My primary pump failed, the Watchdog was able to cycle 2 times before the battery died.
I attached a Noco G3500 Battery charger, and was able to replace the primary pump over the next 30 minutes without issue. The Noco actually charged the battery while cycling the pump another 2 times.
Question:
Can I leave the Noco G3500 attached to the Battery all the time?
I'd have the Watchdog charger and Noco both attached.
The Noco goes to a maintenance mode after the battery reaches 100%.
thanks
Mark
Old 04-10-16, 09:53 AM
Received 3,628 Upvotes on 3,252 Posts
The watchdog charger is a slow trickle charger. Since you were able to run the pump with the second charger connected it sounds to me like the battery is not taking a full charge any more.
I would not leave the second charger connected to the watchdog without disabling its internal charging circuit.
Old 04-10-16, 11:12 AM
How would I disable the internal charging? its just a circuit board.
Thanks
Mark
Old 04-10-16, 01:14 PM
It's a multi function circuit board so I'm not sure how to disable internal charging.
