Water filter for whole house
For same reason - maybe recent landscaping is to blame - my home well is contaminated with clay dust. What is the cost effective solution to filter the dust out? There is a 1" pipe I can easily access at the pump to add a filter.
You would have to do it on the 3/4" side exiting your tank, as I have not seen many with 1" fittings, but I like putting a 5 micron filter (rope type) and tandem it with a 1 micron carbon filter. Put brass ball valves on either side so you can turn the water completely off to change filters.
Thanks! Can you suggest where to purchase these filters from and what brand/model should I get?
I'm going to have to get something to filter my house water also. Just installed a new kitchen faucet yesterday and before the day was over a piece of debris [PVC shard] blocked the hot water side where it wouldn't shut off
Buying a filter similar to the one shown appears to be the cheapest option. My only concern is how often you may or may not have to change the filter. When my city water goes out I often get trash in the lines
Bitjam, the filter system you showed will work, but not on the 1" pipe and you can't neck the 1" pipe down to 3/4", so placing it after the tank will be necessary where you have 3/4" piping. I would NOT, however use the PVC ball valve. Whoever invented and developed those things should have been tarred and feathered before they hit the market. Nothing but troubles. Use Brass valves.
I was once given a whole house filter as a gift . . . . a Polident I believe it was. And because it was a "gift" I had to use it to keep peace with the giver.
This was before the industry standardized and most all filter cartridges are interchangeable.
I just remember spending an arm and a leg for cartridges which would work in my Polident Filter . . . . very similar to what was readily available in most hardware stores; but different enough so that you had to use theirs and only theirs.
I'm so glad I moved away and was able to say that the Polident had to be left for the new Owners of that house (not quite true), and I now have a generic filter that uses the industry standard cartridges.
And Polident is out of that business anyway . . . . good riddance !
