What kind and size of well pipe to use
Old 02-27-17, 06:00 AM
I am going to be installing a new well pump and pipe and power cable. The pump will be suspended 240 foot below ground. What size and what psi polyethylene pipe do i use.
Old 02-27-17, 07:34 AM
GregH's Avatar
Super Moderator
Received 37 Votes on 35 Posts
The pipe size would be determined by depth and flow rate.
The pipe sizing recommendations you should follow will be in the manual for your pump.
Old 02-27-17, 07:47 AM
Says 1 inch pipe but im using polyethylene pipe so what psi pipe do i need manual dont say
Old 02-27-17, 08:41 AM
C
Received 2 Votes on 2 Posts
So the working pressure at the pump will be (240 feet x 0.433 PSI/ft) + pressure switch cut off pressure.
So if you have a 60/40 pressure switch:
(240 x .433) + 60 = 163.92 PSI working pressure.
I'd use at least 200 PSI pipe.
The .433 psi/ft figure is the pressure loss raising water one foot that has to be overcome by the pump.
Old 02-27-17, 08:50 AM
Awesome thank you so much.
