French drain clogged
Old 08-16-17, 05:49 PM
C
I have tried to work out the funk out of the top and have tried hair and grease remover from Home Depot which works great on most drains.
My tenant doesn't clean it out and leaf and dirt have clogged it.
Any ideas other than calling a pro?
Thanks!!
Charles
Old 08-16-17, 06:00 PM
Can it be sucked out with a shop vac?
Old 08-16-17, 06:36 PM
C
Hey Shorty,
I tried that but not much help...
Old 08-16-17, 06:38 PM
Received 3,485 Upvotes on 3,128 Posts
Usually a French drain is not visible. Do you have a pipe and rock at the ground's surface ?
It's almost impossible to clean the crap out of the rocks. The one drain I have here that is similar to that surface mount one has ground cover screen over it and is easy to wash off.
Old 08-16-17, 06:56 PM
C
I guess it's a French drain...It sits at the bottom of the stairway going into the basement....
Old 08-16-17, 07:00 PM
C
btw, it was built in 1943 and is an old row house in Baltimore...there's no visible pipe or rock as you asked..
Old 08-17-17, 05:45 AM
A
Received 256 Upvotes on 235 Posts
This looks to me like a floor drain, not a French drain.
You need to find out where the water is supposed to go, which could possibly be a dry well directly under the drain opening. Then clean out or reconstruct that facility so the water does not back up at the bottom of the stairs.
A French drain collects water from a large area and channels that water to some discharge point. When working properly, its collection channels never fill with water and back up.
Old 08-19-17, 04:13 PM
C
Thank you, Allen and the rest of you.
I will check with zoning to see what it is...
Thank you again.
