Leechbed information needed
Old 08-30-17, 08:43 AM
F
Need info on leechbed depth
Old 08-30-17, 08:50 AM
Marq1's Avatar
Received 1,137 Upvotes on 1,031 Posts
Has to be lower than your tank outlet!
Old 08-30-17, 09:40 AM
F
How deep should pipe be from take to leechbed and what size gravel
Old 08-30-17, 09:52 AM
Received 753 Upvotes on 658 Posts
There are instances where the leach field is higher than the tank that requires pumping the effluent up to the field.
You need to contact your health dept as they generally have strict rules/guidelines tailored for your area.
When you order gravel just tell them it's for a septic drain field - they'll know which gravel to send out. You could also use a gravel less system.
