Well running dry after shock chlorination
Hi Everyone-
Hoping to get a little bit of help with my problem:
I have a 140 ft. deep well with a 1/2 hp constant speed submersible pump. Pump is approximately 20 years old, runs through a 1 gpm flow restrictor, and then into a 200 gal holding tank within my residence. Pump is controlled by a low pressure cutout switch with adjustable (currently set to 35 minute) cutout time. Water is pumped from the holding tank to my house piping using a jet pump, cycle stop valve, pressure tank, sediment filter, aeration system, and water softener (in that order). We live in a high iron area and a metallic smell is common in our water.
I have had issues in the past with running out of water, but nothing for the last 12 months since having my well professionally cleaned.
This Saturday 9/9, in order to get rid of an iron smell and heavy iron buildup, we shock chlorinated our well and storage tank. Since then, our well production rate has significantly decreased and we seem to be running low on water. We have greatly reduced our water usage (in part due to the chlorine smell) but it isn't helping. Our storage tank was down to 35/200 gallons today and our well was dry.
Any ideas what could be causing this and what we can do to fix it?
My operative theory is that the chlorination within the well dislodged sediment/bacteria which has obstructed the veins leading to the well bore.
Thank you in advance!
One more comment: I'm considering trucking in some water and trying to fill up my well casing with spring water and let it seep out into the veins in an attempt to increase production. Is this a good idea or am I wasting my time hauling water?
Welcome to the forums.
You may have just overdrawn the well in the flushing process.
Found a good piece on iron bacteria....
Shock Chlorination and Control of Iron Bacteria
I don't think pouring the water down the well would be permanently helpful. You may need to truck some water in for your tank.
