Try to rebuild well pump
Old 12-10-17, 10:50 AM
W
I have a 1hp red jacket pump that needs parts replaced on the inside. How would I get the diagram to to service? I started taking it apart but can’t seem to get it to slide out of pump housing
Old 12-10-17, 10:59 AM
Received 3,491 Upvotes on 3,134 Posts
Welcome to the forums.
I need a model number to check for a part breakdown.
Old 12-10-17, 09:32 PM
W
It’s a 100DRJ mod.# C55CXHKW-4104 I finally got it apart and the impeller is in pieces. Where would I start looking for parts at? Every place I look up seems to lead to nowhere. Also it’s a duel pipe and I found a 1hp but it’s only a single. Can I make it work until I get this one rebuilt? Thanks for replying
Old 12-11-17, 12:25 AM
Shows as a discontinued pump from ITT - Goulds. Now owned by Xylem.
The C55CXHW is a motor number.
This is the manufacturer of your pump. Manny exploded views but none of your exact model. Literature Library - Xylem Applied Water Systems - United States
Good deal if it's legit...... amazon./Goulds-100DRJ-Jet-Submersible-Pump/
If it's not too deep single pipe may work but I have a feeling you have a deep jet which will require a two line pump.
Old 12-11-17, 04:55 AM
V
Received 2 Upvotes on 2 Posts
Where are you located ?
I have a friendly Well Driller near by who may have an Impeller in stock for your Gould's Red Jacket 100DRJ mod.# C55CXHKW-4104.
I can ask them later this morning, and maybe put you in touch..
Was that broken Impeller made of a polystyrene that shattered or picked up some gravel ?
I once had a Myers Pump whose Impeller was distorted by frost.
