Any tricks & tips to install the 2" diameter discharge seal grommets
Old 05-08-18, 01:58 PM
Q
Received 1 Upvote on 1 Post
Hello all,
I removed the sewage cover for inspection.
However, I found that the installation of the seal grommets is very difficult even with some wax.
I am able to push one of the 2" grommets into the discharge hole. But I am not able to get the second one seated.
Any tricks?
Thank you
Old 05-08-18, 03:12 PM
XSleeper's Avatar
Received 1,958 Upvotes on 1,755 Posts
Use dish soap and water, or ky jelly, not wax.
Old 05-08-18, 03:44 PM
P
Received 2,256 Upvotes on 2,009 Posts
Lube up the grommet and base well. If you still have trouble get part of it started then use something like a block of wood or hammer to push. Once the rubber is slimed it can be difficult to hold so a block of wood or something else can allow you to push harder to get it into position.
