Check valve/pump
Check valve/pump
I set up a outside temporary sump pump.The pipe only has 1 90 degre angle downhill about 8 or so inches above top of pump.
Since it is all downhill from there will i still need a checkvalve ? andif I need it is it best to install before or after the elbow that is at top?
