Best drain
Best drain
I have a sump in the house that I need to run the effluent to the outside of the house. It's water and about 30 gallons at a time maybe once a week.
I know how to run the pvc out of the house, my question is what is the best way to make it drain? I will bury the pipe about 24" in the ground.
Should I put gravel all through the trench and then use pipe with holes at the bottom so the water drains as it runs out. But what do I use as an end point?
Should I just dig a giant hole and fill it with rock?
Any help appreciated
Thanks
Thanks
