Washing machine draining into sump ?
Old 10-08-19, 06:03 PM
U
I have a home inspection scheduled for this friday and i dont believe that the setup for the washing draining into sump is up to code please help
Old 10-09-19, 02:37 AM
Received 867 Upvotes on 758 Posts
What is about the setup that has you concerned? Grey water is allowed in most locales.
Is this a city/county inspection or connected to a sale?
Old 10-09-19, 02:44 AM
U
It is connected to a sale, I understand that the sump drains into the sewer and the washer is draining into sump , just seems like the set up is not up to code
Old 10-09-19, 02:49 AM
I misunderstood, I was thinking a sump pit out in the backyard or somewhere.
I know what you have was allowed a long time ago, don't know it it still is or not. IMO I'd let it ride and see what happens. IF the home inspector flags it and the buyer thinks it's a problem you'll have time to rectify it.
Old 10-09-19, 02:52 AM
U
I cant seem to add photos it keeps asking for url bit thanks for your time and input
Old 10-09-19, 03:54 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Washers drain into sewer all the time I don't see a problem unless you have a lot of ground water going into sump.
Old 10-09-19, 04:26 AM
Received 297 Upvotes on 267 Posts
Is your sump pump kicking on when the washer drains.
If yes then this is a definite no no as you are probably pumping grey water out to your back yard.
Also if you are using the washer when the sump pump is running due to ground water then you will be doing the same thing so I can see the inspector not passing this.
Old 10-09-19, 12:47 PM
Received 4,082 Upvotes on 3,665 Posts
A little help for picture posting..... How-to-insert-pictures.
Old 10-10-19, 04:40 PM
A
Received 287 Upvotes on 262 Posts
Ground water or gutter water collected by a sump pit or otherwise must not be routed into a septic tank. Most cities do not allow it to b drained into the sanitary sewer.
Washing machine water may be drained to septic tanks or sewers. This should not be collected by the same sump pit that collects ground water or gutter water since the detergent will shorten the life of the sump pump.
