What PVC cement should be used for underground use?
Old 11-03-19, 02:56 AM
G
I have to bury a 2" pvc line underground, due to the grounds somewhat cold and damp conditions what would be the best pvc cement to use? Thanks....
Old 11-03-19, 04:00 AM
P
Received 2,309 Upvotes on 2,054 Posts
You can use any PVC cement. Since it's not plumbing you do not have to use purple primer. You still need primer but you can use clear if you want.
Old 11-03-19, 04:30 AM
A
Received 293 Upvotes on 268 Posts
Buried conduit is not considered watertight regardless of material or joining methods.. The wires inside must be rated for wet locations, for example THWN is a wet rated conductor.
Old 11-03-19, 04:53 AM
G
This is for a sewage injector pump system that will be going to my septic tank. Wasn't sure if they made pvc cement that was better for underground cold and wet ground conditions...
Old 11-03-19, 04:55 AM
the_tow_guy's Avatar
Received 264 Upvotes on 215 Posts
The cement is a solvent, it melts the pieces and they fuse together.
Old 11-03-19, 05:58 AM
G
I understand about the joints fusing together, the temp here is in the high 30s to 40 degrees. I've seen a lot of different cements online, all weather, heavy duty, quick bonding, wet and dry, and regular cement. I didn't want to glue the joints in a cold damp ground and have my joints come loose for some reason, that's why I was asking..
Old 11-03-19, 06:20 AM
Received 873 Upvotes on 764 Posts
The different PVC glues have more to do with the conditions they are being applied under than anything else. Once set they should all preform the same.
Old 11-03-19, 09:41 AM
P
Since it is a plumbing application I would use purple primer. It's no different than clear but the purple color makes it visible to the inspector so they can see that you used primer.
Old 11-03-19, 01:13 PM
G
Thanks, maybe I'll use a faster setting cement seeing the joints will be glued outside in colder weather, I'll be sure to use primer too, thanks again....
Old 11-04-19, 05:09 AM
Marq1's Avatar
Received 1,211 Upvotes on 1,099 Posts
Lots of options for cement, fast/slow/heavy duty etc.
https://www.oatey.com/125874/Category/Oatey-PVC-Cements
