Replacing Deep Well convertible jet pump
2 in deep well with 1 1/4 in drop pipe with Flotec 2" Single Pipe Jet Kit. Horizontal installation.
I plan on replacing the 1hp Flotec Convertible Jet pump with either a Gould’s or Sta-Rite 1 hp convertible jet pump. Same setup.
Question is, will another brand pump work ok with the Flotec 2" Single Pipe Jet Kit, All the pipes are the same size
Welcome to the forums.
My opinion is that yes..... you can use the existing jet.
It's usually more important to use a matched jet with a two pipe system.
