Making large object spin
Old 07-25-16, 07:11 AM
I've been tasked with building some props for our marching band. We are building 8' tall by 3' wide "panels"- (3 sided)- made out of wood (they will have artwork painted on them- building them is not the issue- They want them to rotate during the show so that the kids will turn them to show different sides. I thought of using lazy susan turntable but I am not sure a small one will work right when spinning a large object like this- Any other suggestions on what I use to make this "thing" rotate? (it just needs to rotate -not spin) but easy enough for a kid to turn it
Old 07-25-16, 07:31 AM
Received 98 Votes on 86 Posts
Need more details about how these will be used, what's the bottom going to be; any other detail you can provide.
Old 07-25-16, 07:36 AM
bottom will be a 3/4" piece of plywood (triangle)- 3' x 3' x 3'
Old 07-25-16, 07:48 AM
pugsl's Avatar
Received 76 Votes on 69 Posts
Here is a page with lazy susan, first one will hold up over 1000 pounds.
Woodworkers Supply Search Results for: LAZY SUSAN
I get a lot of things from them with good service.
Old 07-25-16, 07:57 AM
B
Received 37 Votes on 34 Posts
You might want to make your rotating base round and then attach your triangular base to that. That would make it easier to use a larger "Lazy Susan" for the rotating device.
Bud
Old 07-25-16, 08:32 AM
You said marching band so I inferred these would be moving along with the band. Sounds like I'm wrong - other than rotating, these are to be stationary when used?
Old 07-25-16, 09:04 AM
correct- stationary- they will just sit in the backround- every "movement" in the music- someone will turn the triangle (so to speak) from side one to side two. So it should turn fairly easily (But the prop itself will sit stationary)
Old 07-25-16, 09:17 AM
C
Received 2 Votes on 2 Posts
I suggest just using 3 large swiveling casters under the bottom. They are available with 6" and larger wheels or even pneumatic tires so they would roll easily on the grass (assuming this will be out on a field). Advantage of casters is that it will be easy to roll the whole assembly on and off the field. Plus, using 3 wheels would make for a stable base regardless of uneven ground.
Harbor Freight would be one source for cheap large casters.
Old 08-11-16, 07:08 AM
i like the wheel idea since it's simple and only requires 3 smaller casters- it makes it a bit unstable... any other way to make this large "thing" spin while keeping it on a solid flat base? for example- using some kind of pipe in a coupling to sort of "Make" a lazy susan type contraption? Just looking for other ideas rather than wheels in case that becomes an issue
Old 08-11-16, 08:03 AM
pugsl's Avatar
mount a flange fitting on plywood base. Put pipe in and mount turning part on the casters. Drill hole in plywood in center of casters base. I would use two pieces of plywood top and bottom with pipe running through them. Should not tip over that way. here is a fitting from Lowes
Shop pipe fittings at Lowes.com: Search Results
