How to fix these cutting boards
my wife purchased a set of plastic cutting boards. They are great, BUT they slide around on the counter tops. She's old school and won't do anything to keep them in place (wet cloth, paper towel etc) so I'm wondering if there is something I can put on the back to keep them in place. The back has a texture of small dots, here shown up close. Not sure it would take a self stick rubber 'dot' or not. Looking for spray ideas which would also work in the dishwasher (though I'm not above washing them by hand if need be.
I'm trying to figure out what all those plastic bumps are for. If they are plastic..... they are useless.
I've glued little rubber bumpers on all my cutting boards.
I don't know of any spray that will be used temporarily like you need it for.
joecaption voted this post useful.
My guess is no. I wouldn't fool around with non-skid sprays, many of which will come off in the dishwasher. And those dimples make having something solid adhere to the board very difficult.
Depends how thick/rigid the board is.
If it is rigid then adding rubber bumpers should work as LJmax said.
One in each corner and one in the center.
Though I would not put it in the dishwasher.
Thanks everyone. I kind of figured they would be useless. I can't continue using them as they slide across the counter while you attempt to use them and make the possibility of a cut rather easy. I will just trash them.
One thought..... they make this product that is like an ultra thin foam. My mom used it in her RV to keep things from sliding around. I'm guessing there are different names for it. The link is one name. You could just cut a pad to use under the cutting board. It doesn't need to be attached. When it gets dirty.... toss it.
Gorilla grip
Gorilla grip
