Fixing stuck bearing on swingset
Old 06-01-23, 04:46 AM
D
Received 3 Upvotes on 3 Posts
I built my son a swingset with some help I got here. I ordered some swing hangars:
https://www.amazon.com/dp/B09WQX5B5D...roduct_details
However, one doesn't pivot freely. Probably 50% of the area of travel is restricted, beaning that while it does pivot, it is slow, like there's something blocking it. I don't see what is blocking it. Could someone suggest what to do about this?
Old 06-01-23, 04:59 AM
Received 800 Upvotes on 703 Posts
Could it be over tightened?
Old 06-01-23, 05:28 AM
the_tow_guy's Avatar
Received 212 Upvotes on 170 Posts
Or possibly a burr in the casting that's rubbing. If you unbolt the two halves, you should be able to find the cause.
Old 06-01-23, 05:38 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Or is cheap finish and has rusted. Squirt a little lube into it first, see if that helps, then tear apart!
Old 06-01-23, 08:48 AM
D
OK I took it apart. There's some plastic bushing in there that seems to be causing it. It's basically a rubber washer. Can be fixed.
Old 06-01-23, 12:54 PM
Received 3,752 Upvotes on 3,364 Posts
Without seeing exactly what you have there apart.... it's hard to offer help.
I doubt it's rusted.
Amazon is pretty good acknowledging problems.
Let the seller know you have a problem piece. They should send out a new one no charge.
