10 Advantages of Metal Ceiling Tiles Over Traditional Materials
Metal ceiling tiles have been used in construction for thousands of years. These tiles are better looking, more durable, and more versatile than plaster. Here are 10 specific examples.
1—They Add Value to Your Home
Metal ceiling tiles are long-lasting, durable, and elegant. Thus, they add value to your home.
2—They Add Strength to the Structure
Because they are made of metal, these ceiling tiles are impervious to many of the things that could damage a normal, plaster ceiling. Metal ceiling tiles do not rot, crack, or absorb moisture and actually add strength to a building.
3—They Are Moisture-Resistant
A major disadvantage of plaster ceilings is their weakness when it comes to moisture. Accumulated water or condensation can severely damage plaster ceilings. This damage can only be rectified with costly repairs or, in some cases, reconstruction. Properly finished, metal ceilings are impervious to moisture as well as the mold and mildew it causes, which adds to their durability.
4—They Are Less Likely to Crack
Unlike plaster ceilings that can crack or warp with time and other factors such as moisture, a metal ceiling retains its shape and beauty for ages. It won’t peel as plaster ceilings do. The bottom line is that once you install metal ceiling tiles in your home or office, you do not have to worry about upkeep or repairs for a very long time.
5—They Are Available in Many Styles
Metal ceiling tiles are available in many styles such as steel, copper, brass, chrome, and aluminum. They also come in a variety of finishes such as bare, polished, and powder coated.
6—They Can Be Painted to Match Any Décor
Metal ceiling tiles have the great advantage that they can be finished to suit any existing décor. This makes metal ceiling tiles a very versatile choice for any project.
7—They Require Minimal Maintenance
Once installed, metal ceiling tiles require minimal care and maintenance. All you need to do to make them last is dust them from time to time.
8—They Are Fire-Resistant
Because they are made of metal, these tiles also have higher resistance to fire, making them safer.
9—They Are Easy to Install
Metal ceiling tiles are much lighter and easier to install than regular plaster ceilings. The whole process will take you less time as well.
10—They Hide Imperfections
Metal ceiling tiles are ideal for covering unsightly plaster ceilings that are in need of repair. Overall, the ease of installation and beauty of these tiles make them ideal for renovations.
