10 Amazon Prime Day Home Improvement Deals in 2022
a man holding a screw gun with tools on a table
  • 1 hours
  • 5-100
It’s always a good time for home improvement, but when Amazon Prime Day deals roll around, you might find the extra inspiration you’ve been looking for to start a new project or upgrade your space.
This year, Amazon Prime Day is actually two days—July 12th and 13th. You have to be a prime member to get these deals. If you're not already, you can sign up here.
1. Frogtape Painter’s Tape, Three-pack
green frog tape rolls
Even if you don’t have a painting project on the calendar this month, Frogtape is like a pantry staple for DIYers. Grab a pack while it’s on sale. Three rolls add up to 60 yards of protection when the time and motivation launch you into your next paint adventure.
2. Brita Tap Water Filter System
water filter on faucet
Filter water directly from the faucet with a name you’re already familiar with--Brita. For $17 on Prime Day, you can filter 100 gallons of water, which for most people is about four-month’s worth. Filters are quick and easy to replace, and an indicator lets you know when it’s time.
Equivalent to approximately 1,800 single-use plastic bottles annually, making the switch results in budget savings and is a necessary choice for the environment.
3. GE LED Outdoor Security Flood Light Bulb with Motion Sensor
If you need light bulbs for any part of your home, check out the sale. This floodlight bulb is one example at 25% off the typical sales price and around 50% off the standard retail price. It’s more than a light, it’s a security measure.
With a built-in motion sensor, the bulb turns on for five minutes when it senses motion, alerting you of activity outdoors or giving you safe illumination when arriving home after dark.
4. Door Reinforcement Lock
hand installing door lock support
While we’re discussing boosting up your home’s security, consider adding a security lock. Normally around $17, this lock should be less than $7 on Prime Day. It’s designed to withstand 800 lbs. of force, reducing the chances anyone could kick the door in or tamper with it from the outside in any way.
5. Sylvania LED Utility Shop Light
Illuminate your workspace for less than $15. These lights are easy to mount and plug in anywhere you have access to an outlet or cord. They can be linked together for a series of up to eight lights. Each features a pull chain for easy operation.
The energy-efficient LED 30W setup offers cool white light to any space that needs a little extra.
6. C by GE Smart Dimmer Light Switch
Go smart with your lighting with this Bluetooth-capable dimmer switch. This works in conjunction with standard bulbs, so you can still have energy savings and control without shifting all your fixtures to smart bulbs (although there are several on sale like these and these).
Hook your smart dimmer up to your phone via the App, and you can control it from anywhere.
7. Kohler K-23725-NA Cast Iron Cleaner
cast iron cleaner on sink
If you have cast-iron fixtures in your home, grab a bottle of cleaner while it’s discounted for Amazon Prime Day. Use it on enameled cast iron throughout the kitchen and bathroom.
8. Scotch Felt Furniture Pads for Protecting Floors
Sometimes home improvement is about preventing damage you’ll need to repair later. Equip all table and chair legs with the appropriate size to pad to protect hardwood, vinyl, and engineered flooring from scratches. With 162 pads in a variety of sizes, you’ll have your legs covered in no time.
9. Kasa Outdoor Smart Plug
smart plug
It’s one of those things you may never have even considered, but smart plugs offer a host of benefits. They're convenient to use, give you control over a variety of functions through your home’s device hub or smartphone App, and save energy too.
This one will be on sale for around $14 and can be set with a timer to auto-control lighting, sprinklers, and other outdoor devices. It doesn’t require a hub with line-of-site wi-fi but is compatible with Alexa, Google Home & SmartThings.
10. Mayfair NextStep2 Toilet Seat with Built-In Potty Training Seat
Make the toilet seat accessible for all, including the smallest members of the household. This toilet seat with a lid is two toilet seats in one. The child’s seat is removable for cleaning, but otherwise raises and lowers just like any other toilet seat.
It’s available in round or oblong to match your setup. The product is equipped with a no-slam lid to protect little fingers and parents’ sanity.
