11 Trees That Require Little Water
Whether you're in a drought or just want a low-maintenance yard, there are some trees out there that require very little water. This makes them great options for a variety of climates and budgets.
And worry not, some of these trees are actually quite pretty and some will even flower in the spring and produce fruit.
1. Blue Spruce
The blue spruce is a great option if you are looking for a low water tree. The blue spruce is known for producing a lot of shade, which can be a welcome break if you have a yard without much shade.
The trees do best in cooler climates and can grow quite tall when properly cared for.
2. Desert Willow
The desert willow, once established, will require rainwater. The tree is slightly smaller than other trees on this list but is still a great tree option if you are looking for something low maintenance.
These trees grow incredibly quickly and will sprout flowers that attract hummingbirds, making them a great option to add beauty to your home while not investing in a tree that requires a lot of water.
3. Bottlebrush Tree
The bottlebrush is another great tree that requires very little water. These trees bloom and create a beautiful landscaping feature.
Bottlebrushes, while a tree, are often dense and compact making them look more like hedges. This also makes them a great option if you are trying to create some privacy in your home.
4. Coast Silktassel
5. Jujube
The jujube tree is a low water plant that only needs to be watered deeply once a month. In addition to being a beautiful addition to your garden, this tree creates edible fruit.
Jujubes spread wide as they grow so this is not a great option for someone with only a limited amount of space in their yard.
6. Palo Verde
The palo verde is a dessert tree that has beautiful yellow flowers and colorful bark. Be careful, though, the flowers and bark hide branches that are quite spiny.
This tree is a great option for anyone wanting to add some shade in their garden. Instead of the shade coming from leaves, with a palo verde, it comes from the twigs.
8. Smoke Tree
The smoke tree requires more water than some of the other trees mentioned on this list, but it still needs less water than the average tree. During hot months it will require more water than during other times of year.
The tree does not grow very tall and is known for its bright colors, such as green, purple, and gold depending on the time of year.
9. Crepe Myrtle
This tree does well in hot areas. When properly cared for, it will bloom in summer and be incredibly colorful come fall.
These plants can grow in colder regions but will flower less and are more susceptible to issues like mildew.
The plant can grow up to 25 feet tall and wide.
10. Loquat
The loquat tree is native to China. These trees have leaves with a pointed end and are often used for decor inside.
The trees produce edible fruit in the spring with a somewhat tart flavor.
11. Olive
