12 Tips for Reducing Your Car's Diesel Consumption
It is prudent to keep an eye on your diesel consumption not only to save money, but also to protect this source of fuel. Follow the tips below to lower the amount of diesel your cars uses.
- Turn off the car. When you let the engine idle, your car gets 0 mpg. Keep in mind that idling for more than 10 seconds uses more fuel than re-starting the engine.
- Get regular tune-ups. Before starting any road trips, make sure that you tune up the vehicle. This will not only help you save fuel, but also head off any future problems with the engine.
- Drive straight. On average, people end up spending more time waiting for a left turn, which leads to an increase in the consumption of fuel. Avoid turning wherever possible.
- Check your tires. Make sure that you check the air pressure of the tires on your vehicle. Repeat this once a month, as under-inflated tires increase the level of fuel consumption of the vehicle.
- Avoid dragging the engine. Try to avoid climbing long hills on high speed. It is much better to apply light throttle while climbing hills in order to save fuel. This will also help in protecting the engine of the vehicle from overheating.
- Gradually increase speed. Be mindful while using the accelerator. You should make sure that you start the vehicle gradually and also stop it in a steady manner.
- Avoid any jerks. Many people end up constantly pumping the throttle, which leads to the consumption of fuel.
- Stay in low gears. Shifting gears at the lowest revolutions per minute assists in improving your gas mileage.
- Keep windows shut. Driving with your windows open will reduce the fuel efficiency. It is better to keep your windows shut and the air conditioning on instead.
- Buy fuel saver tires. While you are shopping for replacement tires, make sure that you look for the fuel saver types. They will have labels on them such as economizer, low rolling resistance or even labels like energy efficient.
- Stabilize the speed of your vehicle. Make more use of the cruise control while you are driving on a highway, as this will help to promote consistent speed and increase the fuel efficiency.
- Avoid traffic congestion. Frequent stopping consumes a huge amount of fuel. Keep in mind that you get zero mpg while idling.
