2 Remodeling Ideas for Mirrored Closet Doors
Mirrored closet doors are often blasted by other people because of the old fashioned air it allegedly exudes in the room. However, that isn’t always the case. You can always modernize your current closet and make it look relevant in your room. All it takes is a little bit of creativity and a discriminating eye.
Repaint the Closet
Mirrors are useful for adding brightness to any room. However, this quality is only heightened if the mirror is placed in closet that is painted a dark shade. If your mirrored closet is painted a light yellow or pink, repaint the closet with a bolder brown or dark blue.
Change the Wood Frames
Mirrored closet doors can actually be modified so they fit in with your other pieces of furniture. You can always look for frames that match your home’s theme. For instance, an elaborate frame can fit in a baroque, elaborate bedroom. At the same time, you can replace any such kind of frame for a common one if you’re going for a sleek, minimalist look. You can also find frames in different finishes so that you can coordinate your closet with the other things found in your room.
